Breathe new life into your Tormek sharpening machine
After many years of use, the drive wheel in your Tormek may need to be replaced. If your drive wheel is worn out, the rubber has dried or the wheel is damaged, you can easily replace it with the R-21 Drive Wheel with Rubber Ring T-4 T-2 T-1. This breathes new life into your Tormek sharpening machine, and you can keep your tools sharp – hopefully for many years to come.
Fits the Tormek T-1 Kitchen Knife Sharpener, Tormek T-2 Pro Kitchen, Tormek T-4 Original and Tormek T-4 Bushcraft, as well as older machine models with a grinding wheel 200 mm (7 7/8") in diameter.
Has the drive wheel on your Tormek given up after many years of faithful service? The Tormek R-21 Drive Wheel with Rubber Ring T-4 T-2 T-1 is a spare part that breathes new life into your Tormek. This drive wheel is the same as the one fitted in the Tormek T-1 Kitchen Knife Sharpener, Tormek T-2 Pro Kitchen Knife Sharpener and Tormek T-4 sharpening machines, as well as older machine models with a grinding wheel 200 mm (7 7/8") in diameter.
  • Replacement drive wheel for refreshing a worn machine.
  • Fits Tormek T-1, Tormek T-2 Pro, Tormek T-4 and older 200 mm Tormek models.
  • Easy to replace and install.
140 g
Black
ABS plastic, RKX18 rubber
