Tormek T-4 Black
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
5,200 kr
7,400 kr
AX-40 Vorrichtung für Äxte
4,600 kr
24,300 kr
RB-180 Drehscheibe
6,000 kr
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
