Tormek T-4 Black
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
¥5,200
¥7,400
AX-40 Vorrichtung für Äxte
¥4,600
¥24,300
RB-180 Drehscheibe
¥6,000
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
