Tormek T-4 Black
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
52,00 lei
74,00 lei
AX-40 Vorrichtung für Äxte
46,00 lei
243,00 lei
RB-180 Drehscheibe
60,00 lei
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
