Tormek T-4 Black
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
52.00TL
74.00TL
AX-40 Vorrichtung für Äxte
46.00TL
243.00TL
RB-180 Drehscheibe
60.00TL
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
