SB-250 Blackstone Silicon
€248,00
Sale price  €248,00 Regular price
Tough on the toughest
The combination of grit hardness, shape and size makes the SB-250 Blackstone Silicon work efficiently at the low rpm speeds of the Tormek machine. The higher abrasiveness of the stone is especially valuable when shaping tools with a large bevel or sharpening surface where the grinding pressure is low, such as planer blades and woodturning chisels.
The SB-250 Blackstone Silicon fits the Tormek T-8, Tormek T-7 and earlier Tormek models with a grinding wheel 250 mm (9 7/8") in diameter and 50 mm (2") wide.
Efficient material removal, for a long time
The SB-250 Blackstone Silicon has sharpening properties equivalent to 220 grit. The SP-650 Stone Grader allows the surface of the stone to be adjusted up to an equivalent of 1000 grit. Its sharp and relatively small grits mean it sharpens efficiently even at low sharpening pressure. This means that the SB-250 Blackstone Silicon holds its shape exceptionally well over time and thus has a very long service life.
€248,00
Tormek's SB-250 Blackstone Silicon has been developed specially to shape and sharpen HSS and other high alloy steels. This makes it popular with woodturners, among others, with its more efficient material removal on hard woodturning tools. The SB-250 Blackstone Silicon has an adjustable characteristics equivalent to between 220 and 1000 grit.
  • Surface can be adjusted to approximately 220–1000 grit.
  • Sharpens effectively with lower grinding pressure.
  • Designed for efficient sharpening of HSS and other high-alloy steels.
  • Fits Tormek T-8, Tormek T-7 and older models.
4.45 kg
Black
Silicon carbide
