RM-533 Rubber Work Mat
Enhances your sharpening
The RM-533 Rubber Work Mat provides a convenient and clean base for your sharpening system. It's not unusual to spill a little water when sharpening, especially when working with longer tools. This rubber work mat is the perfect base, in that case – it retains the water with its raised edges so you can easily wipe it away when you're done sharpening.
Not only is the natural rubber waterproof, it also prevents anything you put on it from slipping around. And what's more, the RM-533 Rubber Work Mat comes with thick rubber, which reduces vibrations when sharpening. Quite simply, what you get is a more convenient, comfortable and ergonomic sharpening experience.
The RM-533 Rubber Work Mat gives you a waterproof, non-slip work surface. This rubber work mat is made of thick natural rubber. It has a raised edge that keeps liquids on the mat. The RM-533 Rubber Work Mat protects you from vibrations, your work area from liquids and your newly sharpened tools from hard knocks.
  • Catches spilled water, honing compound and dirt.
  • Non-slip surface.
  • Suitable for all Tormek sharpening machines.
  • Fits TS-740 Sharpening Station and is included with it.
  • Natural rubber helps reduce vibration.
1.62 kg
Black
Natural rubber
