DWF-200 Diamond Wheel Fine
Sharpens most kitchen knives
The DWF-200 Diamond Wheel Fine is supplied as standard with the Tormek T-2 Pro Kitchen Knife Sharpener. This diamond grinding wheel allows you to sharpen knife blades made of all kinds of different materials, such as steel, carbide and ceramic. After sharpening, deburr and polish the new bevel on the PW-160 Conical Composite Honing Wheel.
This fine-grained diamond grinding wheel is 600 grit. It's optimized to provide maximum sharpness and efficient material removal without removing more material than necessary. This will keep your knives sharp for longer.
The DWF-200 Diamond Wheel Fine is a spare grinding wheel for the Tormek T-2 Pro Kitchen Knife Sharpener. You can easily replace your regular diamond grinding wheel if it's damaged or worn out. The DWF-200 Diamond Wheel Fine is 600 grit.
  • Easy to mount.
  • 600 grit.
2.94 kg
Steel, diamond coating
