Breathe new life into your Tormek sharpening machine
After many years of use, the drive wheel in your Tormek may need to be replaced. If your drive wheel is worn out, the rubber has dried or the wheel is damaged, you can easily replace it with the R-23 Drive Wheel with Rubber Ring for T-8. This breathes new life into your Tormek sharpening machine, and you can keep your tools sharp – hopefully for many years to come.
Fits the Tormek T-8 Original and Tormek T-8 Custom sharpening machines, as well as older machine models with a grinding wheel 250 mm (9 7/8") in diameter.
Has the drive wheel on your Tormek given up after many years of faithful service? The Tormek R-23 Drive Wheel with Rubber Ring for T-8 is a spare part that breathes new life into your Tormek. This drive wheel fits the Tormek T-8 Original and Tormek T-8 Custom sharpening machines, as well as older machine models with a grinding wheel 250 mm (9 7/8") in diameter.
  • Replacement drive wheel for refreshing a worn machine.
  • Fits Tormek T-8 Original, Tormek T-8 Custom and older 250 mm Tormek models.
  • Easy to replace and install.
620 g
Black/gray
Zinc, RKX18 rubber
