For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
- Width: 8" (204 mm)
- Depth: 7 ¾" (196 mm)
- Height: 7 ⅛" (181 mm)
Cord
- Cord length: 5.5 ft (1.7 m)
Grinding Wheel
- Speed: Maximum 200 rpm
- Single-phase AC motor
- Frequency: 50–60 Hz
$5,600
$14,800
$13,800
$9,400
$1,660
KPP-2 Knife Protection Pads
$625
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
