Tormek T-4 Bushcraft
Scandinavia · 230V
4.180,00 kr
Sale price  4.180,00 kr Regular price
4.180,00 kr
VersionScandinavia · 230V
  • Supplied with KJ-45 Centering Knife Jig and AX-40 Axe Jig for outdoor tools.
  • RKX18 drive system.
  • Cast-zinc top with precision mounts.
  • Maintenance-free AC motor designed to maintain speed under load.
10.17 kg
Green/gray
140 rpm. Torque 8.4 Nm.
Scandinavia · 230V
Article no.: T-4 BUSH-AX/SCAND
Instruction Manual
View
WM-200 AngleMaster to measure the existing bevel angle and set the sharpening angle
PA-70 Honing Compound used on the leather honing wheel
KJ-45 Centering Knife Jig for sharpening all your hunting, fishing and outdoor knives
AX-40 Axe Jig so that you'll always have a sharp axe with you
Sign up
Durable Knife Edges
Durable Knife Edges
