Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
- Article no.: T-4 BLACK/EUR
Sharpening Jigs and Accessories
366,00 kr
SE-77 Square Edge Jig
514,00 kr
AX-40 Axe Jig
323,00 kr
1.747,00 kr
KSK-106 Knife Sharpening Kit
2.225,00 kr
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
