Composite Honing Wheel
145 mm
€72,00
Sale price  €72,00 Regular price
Cleaner honing
The Composite Honing Wheel is suitable for use in clean environments as you don't need to use honing compound. Instead, it has polish integrated into the composite material. You can deburr the edge quickly and get great results without getting yourself or your work station dirty!
Wet for more feel
You can wet the Composite Honing Wheel with a little water for smoother honing. Use a sponge or cloth dipped in plain tap water. Hold it against the honing wheel with the machine running. This gives a softer feel to honing if you otherwise find it to be a bit aggressive.
CW-145 Composite Honing Wheel
€72,00
Size
The Composite Honing Wheel is perfect for quickly deburring the edge. It comes with an integrated polish and is easy to use. You can also use your composite honing wheel for regular maintenance and to quickly regain sharpness when you don't need to establish a new bevel.
  • Can be used to maintain tools between sharpenings.
  • Durable composite material with integrated polishing compound, so no honing compound is needed.
  • Vegan alternative to a leather honing wheel.
  • Quickly removes the burr after sharpening.
270 g
Black
ABS plastic, composite
