For professional chefs
- Quiet operation at 54 dB.
240 × 210 × 285 mm
7.8 kg
8.6 kg
140 rpm. Torque 8.4 Nm.
- Article no.: T-2 PRO/EUR
253 Ft
273 Ft
DWC-200 Diamond Wheel Coarse
273 Ft
SC-60 Scissors Jig
70 Ft
200 Ft
17 Ft
KPP-2 Knife Protection Pads
6 Ft
Be the First to Know
Sign upProfessional Sharpness
Built to Last
The Diamond Grinding Wheel
The Patented Angle Guide
The Composite Honing Wheel
