Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
- Article no.: T-4 BLACK/EUR
Sharpening Jigs and Accessories
$52.00
SE-77 Square Edge Jig
$74.00
AX-40 Axe Jig
$46.00
$243.00
KSK-106 Knife Sharpening Kit
$317.00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
