With this diamond wheel, you can sharpen nearly any type of material, including steel, ceramic and carbide. DC-200 Diamond Wheel Coarse fits Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3 and earlier models with a 200 mm diameter grinding wheel.
DC-200 Diamond Wheel Coarse does not leave a fine finish, but should be followed by sharpening with a more fine grained grinding wheel, such as the DF-200 Diamond Wheel Fine or the DE-200 Diamond Wheel Extra Fine.
Simplifies repeat sharpening
Get a completely flat bevel
Take Care of Your Gems
Design protected Ⓓ.
DC-200
The Diamond Wheel Coarse is designed to provide effective sharpening and rapid repair of a dull or damaged edge. The diamond wheel has a grit size of 360 for fast steel removal and is particularly useful for tool shaping.
- Sharpens all types of steel and ceramic.
- Side sharpening makes it possible to create a flat bevel.
- Coarse grit for fast steel removal, repair and reshaping.
- Durable diamond abrasive.
- Maintains a constant shape and diameter.
3.18 kg
5.65 kg
- Safety data sheet ACC-150 EN 2024 (Opens in a new window.)
- Important information regarding diamond grinding wheels (Opens in a new window.)
- Mounting grinding wheels (Opens in a new window.)
