Stainless Steel Main shaft T-8 with Ezylock
€55,00
Sale price  €55,00 Regular price
Durable main shaft
As you can tell from the name, the MSK-200 Stainless Steel Shaft with EzyLock is made of stainless steel for maximum service life. With the Tormek EzyLock, which works as both a nut and a washer, it's easy to mount the grinding wheel with nothing but your bare hands. The large pitch of the left-hand washer nut causes the rotational force of the grinding wheel to tighten the nut.
Change your grinding wheel easily with EzyLock
If you need to replace your grinding wheel, turn it clockwise while holding the honing wheel with your other hand. The EzyLock nut will then automatically release. This design makes it easy to work with different grinding wheels. When mounting the grinding wheel, turn the EzyLock nut counterclockwise by hand. When you start sharpening, the nut will automatically be tightened to the correct torque.
Works with old and new drive wheels
The newer drive wheels manufactured from 1993 onwards have a deep groove for the drive pin. You use the pre-drilled hole on these.
Older drive wheels manufactured before 1993 have a shallower groove for the drive pin. If you have one of these, you can either buy a new drive wheel (art. no. R23) or drill a hole 4 mm (0.16") in diameter. More information can be found in the Instructions MSK-250 EN document.
They fit the Tormek T-8, Tormek T-7, Tormek 2000 and older models with a 250 mm (9 7/8") diameter grinding wheel.
€55,00
The main shaft, nut and EzyLock are all made of stainless steel. EzyLock ensures that the grinding wheel is securely fastened, with no risk of loosening. No tools are needed to fit or remove the grinding wheel thanks to a unique design.
  • Replaces an old shaft and can extend the service life of the machine.
  • All components are stainless steel for long-term use.
  • Fits Tormek T-8, Tormek T-7, Tormek 2000 and older 250 mm models.
  • Easy to replace.
480 g
Stainless steel
