Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
$ 52.00
SE-77 Square Edge Jig
$ 74.00
AX-40 Axe Jig
$ 46.00
$ 243.00
RB-180 Rotating Base
$ 60.00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
