Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
52.00 SR
SE-77 Square Edge Jig
74.00 SR
AX-40 Axe Jig
46.00 SR
243.00 SR
RB-180 Rotating Base
60.00 SR
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
