Tormek T-2 Pro Kitchen
EU · 230V
For professional chefs
  • Fine diamond grinding wheel for a sharp, durable edge.
  • Can sharpen round rotary blades with RBS-140 Round Blade Sharpening Attachment.
  • Replaceable diamond grinding wheel available in three grit sizes.
  • Patented guide supports a consistent sharpening angle and bevel.
  • Felt in the guide helps protect knives from scratches.
  • Magnet in the guide captures steel particles.
  • Quick, straightforward setup.
  • Designed for professional knife sharpening in about 60 seconds.
  • Quiet operation at 54 dB.
  • Can sharpen kitchen scissors with SC-60 Scissors Jig.
  • Separate composite honing wheel with integrated polishing compound.
240 × 210 × 285 mm
7.8 kg
8.6 kg
140 rpm. Torque 8.4 Nm.
Instruction Manual
View
KPP-2 Knife Protection Pads fitted in the guide
Two edge protectors for your newly sharpened knives, at 36 and 63 mm wide
Compatible with Tormek T-2
DWC-200 Diamond Wheel Coarse
SC-60 Scissors Jig
SC-60 Scissors Jig
SC-60 Scissors Jig
SC-60 Scissors Jig
SC-60 Scissors Jig
Be the First to Know
Sign up
Professional Sharpness
Built to Last
Built to Last
