Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
₴52.00
SE-77 Square Edge Jig
₴74.00
AX-40 Axe Jig
₴46.00
₴243.00
RB-180 Rotating Base
₴60.00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
