Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
- Article no.: T-4 BLACK/EUR
Sharpening Jigs and Accessories
5.200₫
SE-77 Square Edge Jig
7.400₫
AX-40 Axe Jig
4.600₫
24.300₫
KSK-106 Knife Sharpening Kit
31.700₫
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
