Tormek T-4 Black
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
LE 52.00
LE 74.00
AX-40 Vorrichtung für Äxte
LE 46.00
LE 243.00
RB-180 Drehscheibe
LE 60.00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
