Tormek T-4 Black
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
52 Ft
74 Ft
AX-40 Vorrichtung für Äxte
46 Ft
243 Ft
RB-180 Drehscheibe
60 Ft
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
