Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
- Article no.: T-4 BLACK/EUR
Sharpening Jigs and Accessories
$5,200
SE-77 Square Edge Jig
$7,400
AX-40 Axe Jig
$4,600
$24,300
KSK-106 Knife Sharpening Kit
$31,700
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
