For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
56,00 Kč
148,00 Kč
138,00 Kč
94,00 Kč
16,60 Kč
KPP-2 Knife Protection Pads
6,25 Kč
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
