Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
52,00 Kč
SE-77 Square Edge Jig
74,00 Kč
AX-40 Axe Jig
46,00 Kč
243,00 Kč
RB-180 Rotating Base
60,00 Kč
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
