Fine-grained for best all-round results
The DF-150 Conical Diamond Wheel Fine is 600 grit. This gives you the best of both worlds – you don't remove more material from the blade than you have to, and the sharpening process is fast and straightforward. When you're done sharpening, deburr add the final touch to your knives on the PW-160 Conical Composite Honing Wheel.
How long does the diamond grinding wheel last?
The DF-150 Conical Diamond Wheel Fine keeps going for a thousand plus sharpenings. It's hard to give a more precise answer, because it depends on how you use it. The vast majority of households are able to sharpen their knives for a lifetime or longer.
The surface of the grinding wheel will become finer and finer over time. If you ever want to get a brand new grinding wheel again, we recommend keeping the previous one for those times when you want a really fine finish.
The instructions for the Tormek T-1 Kitchen Knife Sharpener include information on how to easily replace the diamond grinding wheel.
The DF-150 Conical Diamond Wheel Fine is supplied with the Tormek T-1 Kitchen Knife Sharpener as standard. If your diamond grinding wheel is damaged or worn in any way, you can replace it with a new grinding wheel.
  • Designed for more than 1,000 sharpening sessions.
  • Steel core with a diamond-coated surface.
  • Fits the Tormek T-1 Kitchen Knife Sharpener.
  • 600 grit.
  • Spare grinding wheel for the Tormek T-1 Kitchen Knife Sharpener.
1.42 kg
Steel, diamond coating
