Sharpen your own blades - save time
The SVH-320 Planer Blade Attachment always lets you work with sharp planer blades. You also avoid being interrupted in your work, having to send away blades for sharpening. The jig can sharpen blades of unlimited length. Blades longer than 270 mm (10 5/8") are moved along in the jig and sharpened in two steps.
Always top precision
The SVH-320 Planer Blade Attachment guides your tools precisely and sharpens them straight along their entire length to the sharpening depth you set. This leaves minimal scope for handling errors when the jig is set up correctly. Follow the instructions carefully, step by step, for perfect sharpening of your planer blades.
The Tormek SVH-320 Planer Blade Attachment allows you to sharpen HSS planer blades of any length. Also suitable for miter trimmer blades. Accurate setting ensures precise sharpening along the entire edge.
  • Sharpens planer blades of any length.
  • Works with Tormek T-4, Tormek T-8 and older models; Tormek T-8 is recommended.
  • Patented precision adjustment helps produce matching results along the blade.
1.78 kg
Gray/black
Aluminum, stainless steel, black composite
