For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
5,600 kr
14,800 kr
13,800 kr
9,400 kr
1,660 kr
KPP-2 Knife Protection Pads
625 kr
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
