For professional chefs
- Quiet operation at 54 dB.
240 × 210 × 285 mm
7.8 kg
8.6 kg
140 rpm. Torque 8.4 Nm.
- Article no.: T-2 PRO/EUR
25,300 kr
27,300 kr
DWC-200 Diamond Wheel Coarse
27,300 kr
SC-60 Scissors Jig
7,000 kr
20,000 kr
1,660 kr
KPP-2 Knife Protection Pads
625 kr
Be the First to Know
Sign upProfessional Sharpness
Built to Last
The Diamond Grinding Wheel
The Patented Angle Guide
The Composite Honing Wheel
