€200,00
Sale price  €200,00 Regular price
With the RBS-140 Round Blade Sharpening Attachment, you no longer have to send your round knife blades away to be professionally sharpened. You also prevent them from becoming dull or damaged after honing on a whetstone, which results in varied bevel angles over the blade. Instead, you get a professionally sharpened blade in no time, with the same bevel angle around the entire blade. Your round knife blades never need to leave your restaurant again!
Blades that last longer
Because the RBS-140 Round Blade Sharpening Attachment is used together with the T-2 Pro Kitchen Knife Sharpener, a minimal amount of steel is removed from your rotary knife blades during sharpening. This gives them a longer service life – benefiting both the environment and your wallet. Quick and easy!
Professional sharpening for the best results
Sharpening your round knife blades to professional sharpness is as easy as can be with the RBS-140 Round Blade Sharpening Attachment. After mounting the blade in the accessory, fold it down onto the grinding wheel and start the machine. The accessory is designed so that your round knife blades self-rotate against the fine-grained diamond grinding wheel and are sharpened without you having to do anything more than to start the machine.
After about a minute, the blade is fully sharpened. You then remove the blade and hone it separately on the composite honing wheel to remove the burr that's formed and polish the edge to razor-sharpness (be sure to wear protective gloves!). It's just as easy to do as the blade will be sharp!
Center hole diameter 8 - 15 mm (5/16" - 19/32")
Knife blade diameter 80 - 140 mm (3" - 5 1/2")
Fits most hole profiles
€200,00
Accessory for Tormek T-2 Pro Kitchen Knife Sharpener for sharpening round knife blades. Rotary gyro knife, kebab knife or shawarma slicer – whatever you call it, it's time to sharpen it! The RBS-140 Round Blade Sharpening Attachment fits most blade models for your electric knives with round, rotary blades. The accessory is specially designed and only fits the Tormek T-2 Pro Kitchen Knife Sharpener, which removes a minimum amount of steel and gives you a professionally sharpened blade in no time.
  • Once mounted, the blade sharpens as the machine runs.
  • Sharpens round rotary blades approximately 80–140 mm in diameter.
  • Fits Tormek T-2 Pro.
  • Fits most round-blade hole profiles.
  • Separate honing removes the burr and polishes the edge.
81 × 56 × 226 mm
570 g
Precision-cast zinc, stainless steel, ABS plastic knobs
