Tormek T-4 Original
- Stainless-steel shaft with EzyLock.
- Water cooling prevents the steel from overheating.
- RKX18 drive system.
- Maintenance-free AC motor.
- Compact water-cooled sharpening system for edge tools.
- Cast-zinc top with patented precision mounts.
9.8 kg
Blue/gray
140 rpm. Torque 8.4 Nm.
- Italy · 230V
- Article no.: T-4 ORIG/IT
Knife Care at Your Fingertips
