For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
Rs 56.00
Rs 148.00
Rs 138.00
Rs 94.00
Rs 16.60
KPP-2 Knife Protection Pads
Rs 6.25
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
