For professional chefs
- Quiet operation at 54 dB.
240 × 210 × 285 mm
7.8 kg
8.6 kg
140 rpm. Torque 8.4 Nm.
- Article no.: T-2 PRO/EUR
Rs 253.00
Rs 273.00
DWC-200 Diamond Wheel Coarse
Rs 273.00
SC-60 Scissors Jig
Rs 70.00
Rs 200.00
Rs 16.60
KPP-2 Knife Protection Pads
Rs 6.25
Be the First to Know
Sign upProfessional Sharpness
Built to Last
The Diamond Grinding Wheel
The Patented Angle Guide
The Composite Honing Wheel
