For professional chefs
- Quiet operation at 54 dB.
240 × 210 × 285 mm
7.8 kg
8.6 kg
140 rpm. Torque 8.4 Nm.
- Article no.: T-2 PRO/EUR
1.134,00 zł
1.223,00 zł
DWC-200 Diamond Wheel Coarse
1.223,00 zł
SC-60 Scissors Jig
312,00 zł
895,00 zł
62,00 zł
KPP-2 Knife Protection Pads
25,00 zł
Be the First to Know
Sign upProfessional Sharpness
Built to Last
The Diamond Grinding Wheel
The Patented Angle Guide
The Composite Honing Wheel
