Tormek T-8 Original
Tormek T-8 Original
EU · 230V
3.928,00 zł
Sale price  3.928,00 zł Regular price
Tormek T-8 Original
Tormek T-8 Original
3.928,00 zł
VersionEU · 230V
270 × 270 × 330 mm
393 × 296 × 383 mm
14.8 kg
18.25 kg
Blue/gray
100 rpm. Torque 14.7 Nm.
EU · 230V
Article no.: T-8 ORIG/EUR
Instruction Manual
View
Sign up
