XB-100 Horizontal Base
140,00 zł
Sale price  140,00 zł Regular price
Sharpening with edge trailing
The XB-100 Horizontal Base allows you to sharpen your tools with the grinding wheel rotating away from the edge (edge trailing) instead of into the edge (edge leading). This is a great advantage when sharpening woodturning gouges using the SVD-186 R Gouge Jig, for example. That's because sharpening edge leading with the SVD-186 R Gouge Jig risks causing the blade to catch on the grinding wheel.
Hone your tool with precise jigs
The XB-100 Horizontal Base also gives you the ability to hone your tools using the universal support and jigs, as you can hone edge trailing. This allows you to set the jig for maximum precision when honing.
The XB-100 Horizontal Base was supplied as standard on all S-2000 and S-1200 machines after 8 August 2001. If you have an older machine, you can upgrade it with a horizontal base.
140,00 zł
The XB-100 Horizontal Base allows you to sharpen with the rotation of the grinding wheel running away from the edge (edge trailing) instead of into the edge (edge leading). The XB-100 Horizontal Base was supplied as standard on all Tormek S-2000 and S-1200 machines after 8 August 2001. If you have an older machine, you can upgrade it with a horizontal base.
  • Enables guided honing using the Universal Support.
  • Fits Tormek 2000, Tormek 1200 and older machines made before 8 August 2001.
  • Adds horizontal precision mounts to older Tormek machines.
  • Enables sharpening away from the edge.
150 g
Gray
Zinc
