For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
R 56.00
R 148.00
R 138.00
R 94.00
R 16.60
KPP-2 Knife Protection Pads
R 6.25
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
