Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
R 52.00
SE-77 Square Edge Jig
R 74.00
AX-40 Axe Jig
R 46.00
R 243.00
RB-180 Rotating Base
R 60.00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
