Tormek T-4 Black
Tormek T-4 Black AU 230V Type I
Tormek T-4 Black
TitleTormek T-4 Black AU 230V Type I
9.7 kg
Schwarz
140 U/min. Drehmoment 8.4 Nm.
Jigs and Accessories
View all
AX-40 Vorrichtung für Äxte
RB-180 Drehscheibe
RB-180 Drehscheibe
RB-180 Drehscheibe
RB-180 Drehscheibe
RB-180 Drehscheibe
What is the Tormek T-4 Black?
Sign up
Clean Honing, Sharp Results
