Diamond Wheel Fine
Diamond Wheel Fine
250 mm
Diamond Wheel Fine
With this diamond wheel, you can sharpen nearly any type of material, including steel, ceramic and carbide. DF-200 Diamond Wheel Fine fits Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3 and earlier models with a 200 mm diameter grinding wheel.
Simplifies repeat sharpening
Get a completely flat bevel
Take Care of Your Gems
Design protected Ⓓ.
DF-250 Diamond Wheel Fine
Size
Tormek's Diamond Wheel Fine is the ultimate all-round diamond grinding wheel, combining efficient steel removal with a smooth grinding surface. The wheel has a grit size of 600, providing effective sharpening and a smooth surface finish.
  • Sharpens all types of steel and ceramic.
  • Side sharpening makes it possible to create a flat bevel.
  • Efficient steel removal with a smooth finish.
  • Durable diamond abrasive.
  • Maintains a constant shape and diameter.
5.6 kg
1 bottle of ACC-150 Anti-Corrosion Concentrate that makes the water corrosion inhibitant
