Provides Improved Water Management
We always want to lean towards perfection. With the TF-2 Tilt Feet, the machine is slightly tilted, allowing water to flow from the tool back into the water trough via the drip guard. This closed-loop system ensures consistent performance, prevents mess and waste of products. In other words – no more puddles while sharpening longer tools.
3D Printable – Make Your Own
With the STL file for the TF-2 Tilt Feet you can 3D print your own at home. However, this STL file is provided free of charge for personal use only. Redistribution, modification, or commercial use of this file, including but not limited to selling, sharing, or uploading to any online platform is strictly prohibited.
By downloading and using this file, you agree to these terms. Download the file here. stl, 728.9 kB.
While we don’t have specific recommended settings for printing, we do recommend avoiding low-quality settings to ensure a satisfying result.
TF-2 Tilt Feet
The TF-2 Tilt Feet incline your Tormek T-8 for improved water management. They also secure the main shaft during transportation while allowing you to use the machine without the grindstone. Comes with Tormek T-8 manufactured April 2025 or later and can be purchased at your local Tormek retailer. And the best part? You can get them for free by printing your own at home with a 3D printer.
- Compatible with RB-180 Rotating Base.
- Can be stored on the Universal Support.
- Tilts the machine to improve water management.
- Designed for Tormek T-8.
- STL file is available for 3D printing.
- Allows use of the machine without the grinding wheel mounted.
6 g
10 g
Black
Thermoplastic Elastomer
