Tormek T-4 Black
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
Jigs and Accessories
$52,00
SE-77 Square Edge Jig
$74,00
AX-40 Axe Jig
$46,00
$243,00
RB-180 Rotating Base
$60,00
What is the Tormek T-4 Black?
Clean Honing, Sharp Results
