Tormek T-4 Original
Tormek T-4 Original
Argentina · 230V
Tormek T-4 Original
Tormek T-4 Original
  • RKX18 drive system.
  • Maintenance-free AC motor.
  • Cast-zinc top with patented precision mounts.
9.8 kg
Blue/gray
140 rpm. Torque 8.4 Nm.
Instruction Manual
View
PA-70 Honing Compound which is used on the leather honing wheel
Sign up
Handy Size for Handy People
Knife Care at Your Fingertips
