Diamond Wheel Extra Fine
200 mm
€244,00
Sale price  €244,00 Regular price
With this diamond wheel, you can sharpen nearly any type of material, including steel, ceramic and carbide. DE-200 Diamond Wheel Extra Fine fits Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3 and earlier models with a 200 mm diameter grinding wheel.
The DE-200 Diamond Wheel Extra Fine is especially appraised by woodcarvers and others who needs their bevels to have a mirror finish. If you need to create a new edge or shape, we recommend you do that on a coarser grinding wheel at first, such as the DC-200 Diamond Wheel Coarse or DF-200 Diamond Wheel Fine. Then you can give the finishing touch with the DE-200 Diamond Wheel Extra Fine for a mirror polish.
Simplifies repeat sharpening
Get a completely flat bevel
Take Care of Your Gems
Design protected Ⓓ.
€244,00
Size
The Tormek Diamond Wheel Extra Fine is the diamond wheel that provides an extra smooth finish and is especially suited for sharpening carving tools and knives with minimal steel removal needs. The grit size is 1,200.
  • Sharpens all types of steel and ceramic.
  • Side sharpening makes it possible to create a flat bevel.
  • Extra-fine grit for a very smooth finish.
  • Durable diamond abrasive.
  • Maintains a constant shape and diameter.
3.16 kg
1 bottle of ACC-150 Anti-Corrosion Concentrate that makes the water corrosion inhibitant
