Simple, Secure Setup
With its smart, intuitive design, the SC-60 Scissors Jig’s setup is quick and reliable. Going from dull to razor-sharp is achievable in a few simple steps. Just secure your scissors to the holder, set the angle of the support plate and glide the blade across the grinding wheel. You will have a consistent edge with a simplicity you’ll appreciate and results you can trust.
The hole where you attach the support plate to the universal support has a special wedge shape which increases the locking force by as much as 250% compared to a round hole. You can lock the support plate instantly at the selected angle. This ingenious design is an original Tormek innovation commonly known as the TorLock.
Sharpening Scissors and Shears of Various Shapes
Not all scissors are built the same. Some may have convex blades, some curved and all different shapes and sizes. The SC-60 Scissors Jig’s smart, adjustable design allows you to follow the unique shape of each blade, ensuring a consistent edge along the entire bevel. With the reduced friction and vibration, you will be able to glide the blade smoothly across the grinding wheel safely and accurately (even if the blade might sing a somewhat unpleasent song of joy from being sharpened again).
When used on the Tormek T-2 Pro Kitchen Knife Sharpener, you can sharpen scissors with a blade length up to 120 mm / 4.7" (measured from the pivot point to the tip). Longer scissors can be sharpened only if they are disassembled, allowing each blade to be sharpened separately.
Please note: while the SC-60 Scissors Jig handles standard shapes with ease, it may have limitations when it comes to scissors with unconventional edges such as wavy shears or pinking scissors. You can experiment with different models with the machine turned off, and carefully see if your specific, unconvetional scissors or shears will be sharpenable. We do not recommend using the SC-60 Scissors Jig to sharpen hairdressing scissors due to their specific demands.
SC-60 Scissors Jig
Give your scissors the edge they deserve – with professional precision on your Tormek. The SC-60 Scissors Jig lets you sharpen most types of scissors and shears, from everyday kitchen scissors to heavy-duty hedge shears. The design features a quick 60-degree angle setting, a clamping that grips for enhanced stability and reduced vibration and a hexagonally patterned support plate for low friction. The SC‑60 Scissors Jig fits the Tormek T-8, Tormek T-4 and Tormek T-2 Pro Kitchen Knife Sharpener. No more tossing dull scissors – with the SC‑60 Scissors Jig even your oldest scissors will make the cut. Faster, easier, and more precise. That’s the Tormek Way. Availability may vary during the launch phase.
- Low-friction design helps minimize vibration.
- Works with Tormek T-2, Tormek T-4, Tormek T-8 and older models.
- Custom clamping holds the scissors securely.
- Other angles can be set with WM-200 AngleMaster.
- Quick setting for a 60° sharpening angle.
530 g
Gray/black
Precision-cast zinc, black composite, rubber
