Tormek T-2 Pro Kitchen
Germany · 230V
€867,00
Sale price  €867,00 Regular price
For professional chefs
€867,00
VersionGermany · 230V
  • Fine diamond grinding wheel for a sharp, durable edge.
  • Can sharpen round rotary blades with RBS-140 Round Blade Sharpening Attachment.
  • Replaceable diamond grinding wheel available in three grit sizes.
  • Patented guide supports a consistent sharpening angle and bevel.
  • Felt in the guide helps protect knives from scratches.
  • Magnet in the guide captures steel particles.
  • Quick, straightforward setup.
  • Designed for professional knife sharpening in about 60 seconds.
  • Quiet operation at 54 dB.
  • Can sharpen kitchen scissors with SC-60 Scissors Jig.
  • Separate composite honing wheel with integrated polishing compound.
240 × 210 × 285 mm
7.8 kg
8.6 kg
140 rpm. Torque 8.4 Nm.
Germany · 230V
Article no.: T-2 PRO/DE
Instruction Manual
View
KPP-2 Knife Protection Pads fitted in the guide
Two edge protectors for your newly sharpened knives, at 36 and 63 mm wide
Be the First to Know
Sign up
Professional Sharpness
Built to Last
Built to Last
