For home cooks
- Quiet operation at 45 dB.
Stainless steel main shaft
150 rpm. Torque 2 Nm
- Article no.: T-1 ALO/EUR
- Article no.: T-1 GRA/EUR
- Article no.: T-1 BLO/EUR
- Article no.: T-1 REB/EUR
€56,00
€148,00
€138,00
€94,00
€16,60
KPP-2 Knife Protection Pads
€6,25
Sign upProfessional Sharpness
Sharpening Your Knives
Patented Angle Guide
