Tormek T-4 Black
Tormek T-4 Black ES 230V Type E+F
€538,00
Sale price  €538,00 Regular price
Tormek T-4 Black
€538,00
TitleTormek T-4 Black ES 230V Type E+F
  • Compact, versatile sharpening system compatible with Tormek's range of jigs and accessories.
  • Efficient sharpening and a fine surface finish on a wide range of materials, including HSS, carbide and ceramics.
  • Exclusive SH-200 Hybrid Graystone combining aluminum oxide and silicon carbide abrasives.
  • Grinding wheel surface adjustable from approximately 220 to 1000 grit with the SP-650 Stone Grader.
  • CW-145 Composite Honing Wheel with integrated polish – no honing compound needed.
  • Stainless-steel shaft with EzyLock for easy grinding wheel changes.
  • Water-cooled sharpening prevents overheating of the edge.
  • Special edition with an all-black housing.
  • 5 years warranty plus 3 years upon online registration.
  • Universal support for precise and repeatable sharpening.
9.7 kg
Black
140 rpm. Torque 8.4 Nm.
WM-200 AngleMaster to measure and set sharpening angles
US-103 Universal Support with Micro Adjust for precision sharpening
CW-145 Composite Honing Wheel for deburring and edge maintenance
HB-10 Tormek Handbook, in the language version supplied for the market
SP-650 Stone Grader to adjust the surface of the grindstone
TF-2 Tilt Feet for optimized water management
SH-200 Hybrid Graystone for efficient sharpening of a wide range of materials
EM-15 Edge Marker for setting and replicating an existing edge angle
Jigs and Accessories
View all
KJ-45 Centering Knife Jig
€52,00
SE-77 Square Edge Jig
€74,00
AX-40 Axe Jig
AX-40 Axe Jig
AX-40 Axe Jig
AX-40 Axe Jig
€46,00
€243,00
RB-180 Rotating Base
€60,00
What is the Tormek T-4 Black?
Sign up
Clean Honing, Sharp Results
